2000 ford f150 egr valvemugsy 10-21-2002, 12:04 AM i have a ford f150 with either a bad egr valve or a missing hose. How do you know if your egr valve is bad? and is it worth it to fix it myself? thanks fordman123 10-22-2002, 12:37 PM Are you sure that the EGR vavle is faulty? Which tests have you run to verify this? Has it set a code? if so, let me know More info will help me help you! Fordman 86parky 11-08-2005, 02:12 PM Are you sure that the EGR vavle is faulty? Which tests have you run to verify this? Has it set a code? if so, let me know More info will help me help you! Fordman I'm having the same problem f150 V6 2001 with 60k. Replaced Egr vavle still check engine light still on. Had it reset at Autozone. They told me that the same code came up for Egr. What should i check next? riverwakerider 11-14-2005, 04:20 PM If It Is A Code P0401 Po402 Or P0400 Replace The Dpfe Sensor vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
