fuel pump resistor #14
Google
Web AF
GotoGod
05-12-2007, 11:33 PM
My fuel pump resistor is at #14. Will the by pass deal work for my car? 99 Gp GT In #15 I don't even have a resistor.
3.8L Auto btw
thanx, GotoGod
BNaylor
05-13-2007, 01:14 AM
GTs and SEs with the L36 SII 3800 do not have a fuel pump resistor. #14 is the fuel pump relay. Only L67 equipped GM cars like a GTP have relay #15 (fuel pump speed control) with a fuel pump resistor in the circuit.
GotoGod
05-13-2007, 01:25 AM
My symptoms are a hestitation while warm and stalling at idle. I replaced the icm but no change. The engine runs at 170- 210 degrees for the most part. When it heats up it gets worse.
Usually the hesitation is noticed at accelleration. A slight hestation exsist during cruising speeds. Regardless Im at a loss.
Is there anything else that would cause this problem?
The new icm help in all areas electronic but this hesitation.
Thanks in advance. GotoGod
BNaylor
05-13-2007, 10:21 AM
The best place to start if you suspect a fuel supply problem or you have not done it is check fuel pressure at the front fuel injector rail. There is a Schrader valve located at the fuel pressure regulator where you can connect an automotive fuel pressure tester.
Based on your symptoms another possible component if the problem is at acceleration which is when the PCM goes to open loop mode would be the MAF sensor. Disconnect the electrical connector to the MAF and take it out for a test drive to see if symptoms remain or improve. A bad MAF will also cause stalling at idle.
GotoGod
05-13-2007, 07:59 PM
Ok, that was it. I unplugged the MAF sensor and it ran good. I drove it about 150 miles avg. from 65- 90 mph and (90 mph was while passing other vehicles) I had no troubles.
The change was 100% noticeable. We left it plugged in for 30 seconds and there was a bunch of hesitation. We unplugged it and it was smooth sailing.
Good tip Bnaylor. Might want to post this in the tips and tricks section.
1999 Grand Prix Gt 3.8 L Hesitation
Engine hesitates after it gets warm. The engine will stall at times when stopped. Problem is reoccurring after initial engine temp reaches about 185-190 degrees F. May happen at lower temps as well.
Unplug the MAF sensor on the throttle body. If it clears up the hesitation or removes it altogether. You need a MAF sensor.
Vehicle: 1999 PONTIAC GRAND PRIX - V6-3.8L FI L36
http://www.oreillyauto.com/EW3/externalweb/homepage/images/arrowgray.gif Has K ENG CODE
Oreillys Part number and price.
Item No: 74-50015 $139.99
this is AutoZones version with the exact same part number and price.
Cardone / Mass Air Flow Sensor (http://www.autozone.com/R,APP280383/vehicleId,2527801/initialAction,partProductDetail/store,5850/partType,00151/shopping/partProductDetail.htm)
Warranty - 1 YR (http://www.autozone.com/customer_service/shopping_at_autozone/warranty.htm) 74-50015 Price:
$139.99 87.00 core charge
My air filter was clogged up when I inspected it yesturday. So I went ahead and put a K&N air filter in.
I seen a really good counter top comparrison gadget. Two fans powering the air flow and with a common filter (fram and all other paper filters) the air flow couldnt move a ping pong ball. Put the K&N filter in and the ball launches to the top of a tube. Sold me.
Thanks again for the tip and take care.
GotoGod
Jayrock06
10-10-2007, 04:57 AM
where is the maf sensor located?
BNaylor
10-10-2007, 08:44 AM
It depends on what engine you have. See link below located at our Tips & Maintenance forum for a Series II 3800 engine.
Click here (http://www.automotiveforums.com/vbulletin/showthread.php?t=746374)
Also, please check the date and do not resurrect old threads. Over 3 months old. Your future cooperation is appreciated. Thread closed.
Google
Web AF
