power steering working, then not?
Google
Web AF
italianjeremy
05-11-2007, 08:06 AM
found another little querk in my 94 camry.
once in awhile, the power steering will be like i have none at all, like it will tighten up but not be unbareable. a couple of turns later and its back to normal again. i checked the fluid level and it was ok... any ideas?
thanks :banghead:
Scrapper
05-11-2007, 08:50 AM
try changing the fluid but sounds like your going to need new pump.....good luck....
Scrapper
05-11-2007, 08:53 AM
oh and are you sure something else isn't loose or in a bind? i no you don't want to hear this but also could be the rack...
somick
05-11-2007, 11:51 AM
...or it may be a loose belt.
Sam
Brian R.
05-12-2007, 03:24 AM
Air in the system?
italianjeremy
05-13-2007, 04:18 PM
:wink: ok, got some great news!
apparently the car sat for a few months and the steering knuckle under the hood right by the firewall was drying out. i put some pb blaster on it, then silicone grease spray and bam! like brnad new.
thanks guys!
Brian R.
05-13-2007, 09:28 PM
Good job!
patgig1
11-14-2007, 12:49 PM
I have had a similar intermitant problem with my power steering on my 92 Camry. More recently I've noticed that if I accelerate agressively the power steering will become manual. This will last as long as it takes to hit a rounded curb on the right side (5-15km/h) then the power steering works well. I've observed this alternatance twice now.
Google
Web AF
