One Sided A/cripitripit@cox.net 05-08-2007, 05:24 PM My 2000 Venture his only putting out cold a/c on the passenger side and the rear, but the drivers side and the middle vents blow warm air. A friend suggested something might have come loose in the venting system so i've torn most everything out to take a look. When I turn the temp knob to hot or cold I can see the Diverter Motor working but not sure if it's actually turning what it is supposed to. It does get hotter when turned to hot but I can't get any cold air thru those vents. Suggestions? I pulled the diverter Motor and manually rotated the knob and it seems to work correctly to give more heat but I still only can get cold air out of rear and passenger sides. This is beginning to sound major repair. edsut 05-29-2007, 09:53 PM I've just noticed the same symptom with my 1999 venture. Haven't torn it apart yet (beyond just cleaning out the two filters). If I figure it out I'll let you know; meanwhile, if you do before I do, please let me know as well!!! Ed vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
