94 Grand Prix power window motor replacement help
Google
Web AF
backyardmechanic
05-07-2007, 11:08 AM
I want to replace the power window motor on the passenger side door. I have the door cover off but can not figure out how to remove the motor. It looks like it is held in but rivets which I can remove but since the motor is inside the door and I can not see what will happen when I remove it. I'm sure it is hooked onto the window track somehow but I don't want parts flying off and not knowing where they belong. Any tips on how to safely remove the motor?
Thanks,
Gary
richtazz
05-07-2007, 03:18 PM
You'll need to remove the entire window regulator assembly to replace the motor. The orignial is riveted, the replacement comes with bolts to re-install.
backyardmechanic
05-07-2007, 03:54 PM
Thanks for the reply. My next question is how to get the regulator out from inside the door?
GotoGod
05-07-2007, 09:49 PM
Unblot it from the window. Unbolt the regulator assy from the door. Unplug all the wires. Pull it out motor and assy and all.
backyardmechanic
05-08-2007, 09:31 AM
Thanks for the replies. I see where four rivets and a couple of bolts hold in it place but for the life of me I can't see where I can pull it out through the door. There are only a couple of small holes in the door to pull it through. Will the entire track and motor come out in one piece?
Thanks again
Google
Web AF
