97 Bravada Trans Leak No one can find
Google
Web AF
djackusa
05-06-2007, 04:22 PM
Hello all,
My 97 bravada trans went out had it fixed but all the fluid keeps leaking back out. IT is why it went out in the first place. I have taken it to a lot of shops and dealerships but no one can seem to fix it, I keep a drip pan under it at all times alot of time and money and still cannot find were its leaking out at.
MT-2500
05-06-2007, 05:30 PM
Welcome to AF.
As with any oil leak you need to clean off all old oil and then run it and look for where the leak is coming from.
They do make a dye to put in the fluid and a special light to aid in finding the hard to find leaks.
muddog321
05-07-2007, 06:48 AM
Just as a note to you there is a major seal between the trans and transfer case and if that leaks the fluid will pump into the transfer case and spill out the top air vent - in fact the transmission has a vent too so see if its correctly filled when hot on the dip stick.
Google
Web AF
