97 Rear hub assembly
Google
Web AF
airwave_assassin
05-05-2007, 01:58 PM
I'm going to be replacing my passenger side rear hub assembly today. I read the chilton manual and it seems fairly easy. is it really just remove the tire, take off the cover thing, unplug the sensor, and unscrew four bolts? will i need any special tools? because all i have are sockets. I think its going to be an easy job, mechanic told me he'd do it and it would take him 3 hours. after reading the manual i see no reason for more than 1.5 hours of work. Also a friend of mine keeps swearing the job is a pain in the ass, but he always over complicates things. took him 2 hours to put a belt on. while it takes me 10 minutes. :screwy:
well i'll check back within the hour, if nothing i guess i'm going at this somewhat blind. later
Classicrocjunkie
05-05-2007, 02:45 PM
Its straight forwards as the book describes. I think you need a t-55 bit to remove the 4 bolts. You shouldn't have to touch your brake shoes either which makes things a lot easier.
airwave_assassin
05-05-2007, 04:32 PM
yeah that mechanic is a thief, 3 hours of work my ass, i finished it in 45 minutes. and i didnt have taht special star bit, i broke the nuts loose at the back, and then just held the screw in place with my hand while i loosened em, to tighten em was the same way, and i'm sure i put em on tight enough. Going for a road test in a few minutes when my buddy gets here to follow me to make sure the tire is spinnig true. kind of an expensive part though, 149.99 but eh, sure beats paying 400 bucks at a no name garage. ( 600 had i let mieneke do it)
airwave_assassin
05-05-2007, 06:15 PM
took it for a nice long drive. found some nice curvy roads, and hauled ass around the corners feeling for any vibration, and guess what?... NONE!!! smooth as the day i bought her.
Classicrocjunkie
05-05-2007, 10:14 PM
Tis why i work at an automotive parts store. I love that 20% off discount... mm hmm
Google
Web AF
