power window problemJoan973k 05-04-2007, 08:33 PM When I put the front window up, it goes to the top and then comes half way down again. Any idea what's wrong?:frown: 06chill 05-11-2007, 10:54 PM yea i see it all the time the window motor needs to be reset you need to pull the door off and on the back of the window motor there should be a black patch that covers a hole behind the hole will be a black button on the window motor. press and hold that with the door closed and manualy roll down the window, then manualy roll up the window. let go of the window switch and then let go of the button. try it it should fix it if now let me know i can get the specific procedure. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
