2000 Z24 spark plugs?williamsynis 05-03-2007, 01:24 PM Where is the spark plugs on the 2000 2.4l engine? I need to replace the plugs and the connectors to the coils. I have the parts and the connector is just a boot not a wire. Does anyone know how to go about this? Are they on the back side of the block? jakegday 05-03-2007, 02:55 PM you need to remove the ignition cover, ignition module, the coil packs, and then the spark plug boot assembly, after that you should be able to see the spark plugs, good luck getting to them! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
