No power to radio or cluster in 2000 Cherokee?jamierai 05-01-2007, 05:48 PM I was driving today, and the power to my radio and cluster cut off. I checked all fuses and none appear to be blown. Other suggestions? AlohaBra 05-01-2007, 11:43 PM Pull the cluster first...known bad connector back there...or just pulling out. jamierai 05-02-2007, 08:36 AM Thanks. I found the blown fuse under the hood and replaced it. It worked great. On my way in to work this am, the same fuse popped again, and this time the air conditioning isn't coming on, now, either. Any more suggestions? Thank you! bmwgolfguy 05-02-2007, 11:41 PM I am no mechanic but my 2001 lost its odometer recently. I found out later my windshield was leaking water into the dash. I don't know if this was the cause of the loss or a coincidence. I ended up putting a used cluster to get the OD back. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
