still ticking at cold startupcartman0223 04-29-2007, 04:45 PM I have a 97 k1500 with the 350. Recently I had the truck in for repair for a random tick. (ticked worse with warmer weather:shakehead) He changed the lifters (found 3 that he considered bad) and push rods, and after many tries to adjust the lash, it still ticks on startup if it has set for a few hours. Before it would tick until warmed up, now it only ticks for a few seconds. Does anyone have an idea what he may have missed for it to keep ticking like this? It is a little upsetting to pay out almost $800 for parts and labor for it to still have a "tick". thank you, cartman0223 BIAR 04-29-2007, 04:48 PM Did he check for a lobe going flat on the cam? Also what is the oil pressure when it is ticking? cartman0223 04-30-2007, 10:20 PM He said that he did inspect the cam, and the oil pressure is about 60psi at cold start. he also said that he checked the pressure with a mechanical gauge to verify the pressure vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
