1996 Chev Lumina lost key.....bigcityruckus 04-28-2007, 01:17 PM Hi, I have a 1996 Lumina car which I lost the key....I had the locksmith try with the vas coder (15) different codes and none work...my mechanic then did it his way he put a resistor in a cable under the dash and started the vehicle with 2 screw drivers by the starter....next he ran a clip attched to the starter with a wire which i place on the positive to start all the time...i have to open the hood everytime i start the car...does anyone have a better solution...:2cents: :popcorn: maxwedge 04-28-2007, 02:21 PM Welcome to AF. Contact a Chev dealer see if the factory records still show the resistor/key code for your car, you must prove you own it, and get a key and resistor made up. I assume you have a key to turn the ign. A variable resistor with the the 15 different resistance ranges available should have been able to replace the key resistor at the connector under the dash. Artem F 05-01-2007, 06:44 PM Another temporary option will be to put +12v to the starter relay's fuse - at least, you don't need to open the hood for that and if you have an extra cigarette lighter plug with a wire you can do it more or less conveniently until you solve the problem. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
