instruction changing rear caliper
Google
Web AF
yuri2
04-22-2007, 01:56 PM
I need some help changing rear caliper on 95 z28 disc brakes prefreably printable instructions.
Mr. Luos
04-22-2007, 07:48 PM
It isn't too bad with the right tools.
1. Jack car up.
2. Remove wheel.
3. Remove the brake line into the caliper.
4. Loosen/remove the two bolts holding the caliper to the bracket.
5. Put new pads in new caliper.
6. Reverse order the steps...put the caliper on, tighten bolts, put the brake line back on, etc...
7. Bleed brakes.
8. Enjoy.
izzydjinn
06-26-2007, 04:14 PM
yuri, mr.luos forgot one detail.......... you need to push back the hydraulic cylinders, usually theres two. if you dont push'em back, theres no way the caliper asembly will fit around the disc. and you dont need to remove brake lines, other than that you are set to go, it should take you 45 to an hour with the right tools.
wrightz28
06-26-2007, 04:23 PM
I'd certainly hope the job has gotten done in the past 2 months :yikes:
good catch tho, but on rears, they are twisted back in as they are threaded (most applications) :2cents:
Google
Web AF
