Some kind soul please help me!
Google
Web AF
Xv7vX
10-15-2002, 09:26 PM
Hello all.
The time has come for me to buy a truck. I have chosen a chevy s-10. I want to make it a custom sport truck. I'm not new to mechanics, ive just been doing import cars and working speed.
ANYWAY, i am new to trucks, ive been doing some research and i am a little confused about air bags, or air springs, or air shocks, or whatever they are called.
What i want is something to raise or lower the truck considering i live in chicago and our roads SUCK. I read somewhere that air bags can only be used for a short time, like 3 minutes or so, then they have to recharge. Is this true or am i Just confused? And what would be my best bet to do what i am looking for.
ANY help would be greatly appreciated, since i am new to the scene.
Thanks
Xv7vX
DeViL
11-01-2002, 09:33 AM
Honestly I don't really know much about bags etc. I dropped the idea of putting bags on the front and lowering it. Maybe ask some of the parts stores in your area or read some of the articles in truck magazines. Truckin for example always has tons of demonstrations on how to set up an air ride. They work you through it step by step so it would give you an idea of what you have to do.
Right now I'm thinking real hard about something. $4000 bucks can buy me 4 sets of 20 inch wheels + tires, and the around the same amount can buy me a supercharger + intercooler set up for the 4.3L V6. I don't know which to go with, am I really interested in a lot of power right now, or some bling.
I'm leaning towards 20's though. I've read that a supercharger works best with less restricted air flow, so in another words it would be best to put headers on first before going with the supercharger. No problem but I don't exactly have the money for headers as well as the supercharger and intercooler. So I may just buy the 20's and save up once again.
tree5253
11-05-2002, 08:10 PM
AIR BAGS CAN ONLY GO UP OR DOWN FOR 3 MINUTES BEFORE THEY HAVE TO BE RECHARGED, ONCE YOU PUT THEM UP THEY WILL STAY UP UNTIL YOU LET THE AIR OUT OF THEM. THEY ARE NOT TO BE CONFUSED WITH HYDRAULICS, THEY WILL NOT MAKE YOU TRUCK HOP AROUND LIKE IN LOWRIDER MAGEIZINE THEY ARER SIMPLY FOR CLEARANCE ONLY
curtis73
11-21-2002, 03:41 PM
Airbags are easily misunderstood. I've never installed or used them, but I'm getting ready to soon. I've done alot of research on them.
Airbags CAN be used like hydraulics to make your vehicle "hop." Its just not like hydraulics in how it acts. Hydraulics are capable of intense extension speed, making them suitable to the high-flying jumping noses you see in rap videos. With extensive modification (and even more money) air can be made to rapidly inflate and deflate. It takes huge air tanks, 1" ports and hoses, and huge solenoids. You won't be yanking the tires off the ground, but it will look like hydraulics othewise.
Hydraulics use a liquid which can't be compressed, therefore their height is dependent on how much volume of fluid is in the cylinder. Since the weight of the vehicle is constant, the PSIs remain the same. Air uses a compressible gas and its height is dependent on PSI differences. It also stores the spring air in a flexible rubber bellows making the PSI wildly affectable. Air springs are rated at a max PSI, weight rating, and installed height. If you want to make your truck air ride, set it at the desired height and measure how tall your coils are (or how far it is from the axle tube up to where you'll mount a frame mount). Let's take a hypothetical example of an S-10. You may want springs with an installed height of 7" for the clearance you desire. Since you want to be able to haul some gravel from time to time, maybe 1800-lb springs is what you want. Once they're installed, add air until they come up to 7" and note the PSI. Ride height is where you get optimum RIDE and road characteristics. PSI is inconsequential. It may take 75 PSI in your truck to ride at 7", but the same springs in a plymouth wagon may take 120. The big benefit to air is that when you ride around town with nothing in the bed, 75 is optimal. Throw in a scoop of gravel and pump it up to 7" again while the load is on. Buy a cap? Your new benchmark may be 80 PSI. Its flexible, but one thing it can't do very well is make it a multiple-height vehicle. Straying above or below the ride height causes exponential degradation of the ride quality. At lower heights, it gets "see-saw" like front to back, and allows for unneccessary compression and bottoming out. At high levels it gets really bouncy allowing too little movement. If you're willing to put up with excessive tire wear, bad ride, and other issues to get a multiple-height look, its a great way to go. At least with air, when you return to ride-height it rides well.
Pros:
-adjustability for multiple loads
-cadillac-like ride
-low-maintenance
-Unlike steel springs, by design they work really well at all weights (within the limits of your GVW). Steel springs are a trade off of weight handling and passenger comfort. My F250 with heavy duty springs will haul tons of weight, but absolutely punishes you on anything but brand new pavement. My 66 Bonneville rides like a marshmallow, but one cooler of beer in the trunk and its draggin the tail. Air would solve the problems on both of these vehicles. On the truck it would maintain the weight handling and increase the ride quality. On the car it would improve the weight handling (not GVW) and maintain ride quality.
Cons:
-can be expensive
-corners like a cadillac
I think too many people get discouraged with air because they expect the low-rider on 20" wheels attitude and they end up just wearing out tires and denting oil pans.
Use it for what its intended and it won't let you down from what I understand. If you are looking for good ride, superior load control, and don't mind a step down in handling, air is great. If you want handling and carving corners, stick with steel.
Good luck
Curtis
xboxdave13
03-29-2007, 10:30 PM
i have a 98' s10 regular cab 2.2L and have been a fan of layinbody.com for a long time. i dont have a permanant garage to do extensive modification to make my truck. and make it roll on 26's, lol, however i do wish to lower it. but i dont want to cut the springs or anything permanant like that (i have bad pot-holes). and hydros. are way to expensive. so that leaves air bags.
anyway my question is this: i dont want to cut my truck to pieces. is there a "bolt on" or close to it, air bag setup that i can put in replace of my shocks and get the desired effect.
Google
Web AF
