TH 400 problem part name?4x4playhus 04-21-2007, 10:50 PM I'm trying to id this part. It's from a th400 out of a 4x4 that a friend is rebuilding. He said its from his reverse manual pattern valve body area, and came across it cracked. Its like a plastic cup that holds a spring over the piston in the valve body. Does anybody know the name? Part #? http://www.rockymountainextreme.com/attachment.php?attachmentid=26404&stc=1&thumb=1&d=1177125997 (http://www.rockymountainextreme.com/attachment.php?attachmentid=26404&d=1177125997) http://www.rockymountainextreme.com/attachment.php?attachmentid=26405&stc=1&thumb=1&d=1177126030 (http://www.rockymountainextreme.com/attachment.php?attachmentid=26405&d=1177126030) Thanks, Scott maxwedge 04-22-2007, 11:22 AM Can't access the pics on that site. MT-2500 04-22-2007, 11:37 AM Your dealer should have it or a transmission parts place or transmission repair shop. If you re reffering to the piston in the valve body. Ask for a front accumulator piston some are aluminum. 4x4playhus 04-23-2007, 12:19 PM Thanks guy's that helped! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
