2004 LS Brakes Thumpy- how do I stop that?
Google
Web AF
dmorlow
04-19-2007, 04:57 PM
Ok, I don't know why all my cars have this problem. After a few thousand miles, all of my brakes get thumpy. On my previous cars, I always changed my brakes myself and just figured there has to be something I'm doing wrong. This car, I bought new and the brakes are still OEM original never changed brakes, and they are thumpy. So, the only thing I can think of is that brake wrong. But, when my girlfriend rides with me, she says I drive like a grandpa, so I don't think I brake hard. So, when I replace my brakes soon, some tricks I do to stop it from happening is I scuff up the rotors so they aren't so smooth when I get done. I was taught if I don't do that, the brakes will get glazed. I also make sure the hub is completely clean before putting the rotor on and I adjust the back brakes with the parking brake to make sure it's adjusted properly. Then I make sure to tighten my wheels with a torque rachet to make sure the wheels are the right tightness, which would also make sure the rotors are the right tightness. Yet, all of my brakes are thumpy after driving for a few months. I can't imagine what I'm doing wrong. Like I said, I always just figured I was doing something wrong installing them, but these brakes on my car now, I've never touched them and they do it. My car has about 50,000 miles on it with the original brakes, so it's about time to change them...
57chevyragtop
04-20-2007, 08:47 AM
I think you'll find these brakes are easier to work on than what you are used to doing. And you are probably right that it is time for a change of pads at least. There have been discussions here on the quality of the chevy discs though I have not enountered the problems mentioned, it could be that you are. Your braking habits may play a role in your problem since you mention it has happened time and again on other cars you've had. I don't know if you pump the brakes to stop as was at one time a way some were taught to do years ago which may cause this but I have my doubts. I changed out all 4 of my rotors ( mine were shot at 61k and elected not to have turned because of rust in the vanes) using NAPA Parts and got the best pads for the front and standard for the rear..$180 total cost. Just be sure your flexible lines are in good condition (NO SOFT spots). Clean and Lubricate the slide pins well with brake grease. Sorry couldn't be of more help with the (thumpy) deal. Maybe someone here has a better answer for you.
la1
04-24-2007, 11:12 PM
I also make sure the hub is completely clean before putting the rotor on good idea
adjust the back brakes with the parking brake to make sure it's adjusted properly] Doesn't really matter you have rotors all the way around. The parking brakes have there own surface on the inside of the rotor hub.
Clean and Lubricate the slide pins If it were me I would replace the pins. They may get hot and cooled by the brakes + stress. Get hi-temp grease made for brakes.
dmorlow
05-16-2007, 07:46 AM
I called a local shop and he has a theory that makes total sense. I've never spent a lot for rotors. I'd imagine GM probably puts the cheapest rotors on their car from the factory. Cheap rotors warp when they get hot which would cause the brakes to get thumpy. He told me to get better rotors. I'm shopping around and I can't figure out what is a good rotor. They have many different prices for rotors... but how do I know that spending $25 more per rotor is enough? Why not the one that's $10 more? I can't figure out what to look for in a rotor to tell me it's a well made rotor made out of good strong metal that won't warp. Does people have good recommendations of good rotors? The guy I talked to recommended raybestos rotors... but I can't find raybestos rotors. I see raybestos brake pads everywhere... but I don't see rotors by them.
Autozone sells Duralast rotors, which is their high end rotor. They have another rotor called something like valuelast or something that sounds cheaper and is cheaper. But other than it having a better sounding namebrand and a higher price, I don't know if it's going to be better.
la1
05-31-2007, 11:52 PM
I put Brembo rotors on my 2003 Impala. Just about any aftermarket rotor is better then the factory. Most of the big online auto parts houses have good quality rotors. If you see a brand you like make a post here ( new) with the name of the rotor and price. As far as the warping. I think it is because they use a different metal inside the rotor. They both heat up and cool down different so you get warping.
dmorlow
06-01-2007, 05:40 AM
Well, I took my dad's advice and went to a local shop that's been in business forever that all they do is brakes. They sold us the parts. All they sold was "Wagner" namebrand pads. So I bought the best pads by them for the front and back and bought the best rotors they had. My brakes work like a dream now. I've never had brakes work this good. We'll see how long this lasts.
57chevyragtop
06-01-2007, 08:45 AM
Glad you finally got your work done, Wagner is a good brand, I've used them many times over the years. Been around for a long time.
Google
Web AF
