Day Running Lights
Google
Web AF
rkuchar1
04-17-2007, 07:49 PM
I had a question.
I was wondering what the name of the control (fuse or relay ) for the day running lights are on the 1999 Pontiac Grand AM SE. I
They seem to have stopped working. the head lights/interior/fog lights work fine.
THanks in advance.
xeroinfinity
04-17-2007, 11:57 PM
DRL relay under the hood fuse box.
Though you should have a SVS light on... Is it ?
rkuchar1
04-18-2007, 12:48 AM
SVS lights???what are those..
xeroinfinity
04-18-2007, 01:03 AM
On the dash, if they were lit you would know :grinyes:
It would be dinging and dinging...
also if you have a highbeam headlamp out the DRLs wont work.
rkuchar1
04-18-2007, 01:13 PM
I'll check tonight. if their is a High beam out. you mean when you start the car that ding...
justin0717
04-18-2007, 01:20 PM
if your drls didnt work there would be a light on the dash that says "service vehicle soon" (SVS) its on the right side, near the top. You will see it when you first start the car and all the lights flash. Then after they go out, see if its still on. If it is then check to see if you have a high beam bulb out. If the SVS lamp isnt on, then are you sure they arent working? There are different times when they wont be on. They are only on if your car is in gear, they turn off when the park brake is applied. They turn off when the automotic lamps turn on, or the headlight switch is turned on.
xeroinfinity
04-18-2007, 03:49 PM
the immediate ding is the seat belt, it would probly do it again , as justin0717 said, when you put it in gear during the day.
Degtr
04-18-2007, 03:58 PM
My experience with my '99 GA SE was that the dash warning lights were kind of buggy. I never got the service light when my headlights burnt out. I also never got the battery light either time my alternator died. I would get the washer fluid light, check engine light, tire pressure light, and low fuel light to warn me of other problems as they arose, though. And I know all of the dash lights lit because I could see them during the test that ran just after the car started. The other potential problem with DRLs is that they are not engaging due to a faulty switch at the shifter or the parking brake. To get the DRLs to engage after the engine has been started, the car must be in gear with the parking brake released. If something has gone wrong there, you probably would not have DRLs, nor would you have any warning lights.
xeroinfinity
04-18-2007, 04:35 PM
Both my Pontiacs hav No DRLS ever :D
rkuchar1
04-18-2007, 06:14 PM
for some reason it stopped working...I checked the High Beams they are okay...I didnt think I would be able to tell...another thing I noticed...i dont know if it is on the same relay/fuse/control..
The low gas indicator ding did not come on today...the ETS button doesn't light up on the dash. or the cruise control light doesnt engage.
rkuchar1
04-18-2007, 07:12 PM
I changed the relay...
Where is the DRL sensor and harness located. your post about the exploded view of them...I couldnt tell where they were.
Day time running Lamp Components
1 Sensor - 99-03 GM# 12450121
2 Sensor Harness - 99-03 GM# 12085535
Relay - 99-01 GM# 12135180
- 02-03 GM# 15393412
xeroinfinity
04-18-2007, 09:45 PM
better check teh fuse boxes on the ends of the dash.
anything that corisponds to the things that are not working.
Have you had any wet floors/leaks recently ?
rkuchar1
04-19-2007, 01:57 PM
no; I washed the floor mats that's it...I'll check tonight when I get home from work.
grandma
04-19-2007, 10:51 PM
you like being a smarty arse, huh?
it's a light that says Service Vehicle Soon, there's another one that says Service Engine Soon, as well.
xeroinfinity
04-20-2007, 12:38 AM
Sorry I didnt see this post.
The sensor is located in the defrost vent on the dash.
Good Luck removing it, PITA!
Yes my ass is very smart!
This has all been covered :grinyes:
If you'd have read all the posts you would have seen this :uhoh:
grandma
04-20-2007, 12:40 AM
This has all been covered grinyes:
If you'd have read all the posts you would have seen this :uhoh: :
but if you look I had expanded my nonsense with even MORE information.
rkuchar1
04-22-2007, 07:57 PM
yes I have those lights...
I have also noticed once and awhile the auto door locks (you know when you get above 25km/hr; the doors lock automatically). I have ability to unlock/lock all the doors.
I have checked all teh fuses the relate to the DRL's. I changed the relay under the hood in case. still nothing. I have also checked the fuses that relate to the head lights to..
xeroinfinity
04-22-2007, 09:04 PM
Well the only other things I can suggest is pull the bulbs and see if anythings loose.
Other then that probley should get it scanned with a scanner that can check the BCM, which is usually the stealership.
rkuchar1
04-23-2007, 11:12 PM
sorry about the confusion.
I do not have that light (service vehicle soon)
that is the red one (more serious); I read the owner's manual today.
Again that light. Also the E-brake doesnt light up
xeroinfinity
04-24-2007, 12:43 AM
might have some bulbs out, so they dont light up when you just turn the key on?
Or when you pull the ebrake?
rkuchar1
04-24-2007, 07:46 PM
no; that light does not come on either does the Ebrake light.
Google
Web AF
