GOLF 2.0 1995 it won't start HELP
Google
Web AF
LuanAvdiu
04-13-2007, 08:03 PM
i bought new spark plugs, spark plug cables, fuel pump etc, i'm not getting any spark or any fuel, but the fuel pump is good cause when i connect it directly to the battery works fine. I don't know if it's the computer but it just cranks but no spark no fuel. HELP thank you/
Mike_Van
06-07-2007, 04:13 PM
Fuel pump relay?
vanderwalt
06-08-2007, 06:19 AM
Have a look at the coil-pack . I got a '97 and the coil-pack went on it.
raylfitz
07-26-2007, 10:18 PM
I have a 96 golf that won't start intermittantly and it has no spark when it won't start. Have replaced the coil pack, distributor, engine wire harness, ign switch, computer, and all relays and the problem persists and is getting more freguent. any ideas let me know.
veedubmechanic
07-28-2007, 06:01 PM
Check ignition timing.
kesga
08-28-2007, 11:48 AM
I worked on VW's for over 7 years at a dealership, one thing we always saw with starting problems after someone has replaced ignition components(especially dist cap & rotor) was that some aftermarket rotors would not work with VWs, even if they say it is the right one for your car.
The only ones I have seen trouble free are the BOSCH ones.
hope this helps
kesga
08-28-2007, 12:27 PM
I've also seen bad distibutors causing this, especially in 1995 model year, they integrated the crank sensor with the distributor, so if your sensor is bad, you have to replace the distributor($$$$$)
raylfitz
08-28-2007, 06:00 PM
Thanks for the info, but I have replaced the distributor twice, once with a NAPA rebuilt and then with a Bosch new one, and I still get no spark.
Google
Web AF
