2001 Park Avenue IAC screw
mcmlxv
04-13-2007, 08:00 PM
Cleaned both the Idle Air Control Valve and the Mass Air Flow Sensor yesterday. Big difference in performance. One of the screws anchoring the IAC to the throttle body snapped. Does anyone have a part # for this screw? It's Torx-20 tamper proof.
Thank you.
012620
04-14-2007, 11:38 AM
What method did you use to clean these items. Thanks for the info.
mcmlxv
04-15-2007, 11:21 AM
CRC Mass Air Flow Sensor Cleaner and CRC Throttle Body Cleaner for the IAC.
Worked great.
012620
04-15-2007, 11:46 AM
Worked great.
I guess I also wanted to know if you dissembled your IAC Sensor before you cleaned it. Thanks.
mcmlxv
04-15-2007, 07:35 PM
No, I only removed it and sprayed it thoroughly.
