where is the fuel filter fuse 97 Buick lesabre
davdogg42
04-12-2007, 11:11 AM
I know this might be a dumb question to some of you but when i bought my car last summer the manual was missing.
I had stalling problems the past couple weeks. After reading some posts it seems like a common problem. It stalled once a couple of weeks ago, but started back up. Then after I got home she would crank but no turn over. I let it sit over night then in the morning it started up. I went to auto zone to get it scanned but since the check light lamp wasnt on i coudnt get the codes.
the Buick ran fine the last two weeks but Tuesday she died on me. same thing, would crank but no turnover. Yesterday I went to were it was parked and cleaned the Battery and connections .....crank but no turnover. But I did notice or heard I should say a short out sound from the dash. So I checked the fuses under the driver side, checked out fine. But where the heck is the fuse for the fuel pump, I know it there is one but cant find it. Thanks
P.S. I changed out the Fuel pump back in Nov.
Mickey#1
04-12-2007, 03:50 PM
Looks like you have a typo in the title - no fuse for the fuel filter.:wink:
The fuel pump fuse & relay are under the dash on passenger side.
Have you checked for spark?
LeSabre97mint
04-13-2007, 04:53 AM
Dave
Check out this thread: http://www.automotiveforums.com/vbulletin/showthread.php?t=441482&highlight=97+stalling There might be an answer for you there.
Regards
Dan
davdogg42
04-13-2007, 12:40 PM
its in the shop now, I told the shop to check the wiring leading to the battery and to check the ground bus under the driver side door . Ill let yall know how it comes out. My bet it is the crank sensor. But i hope its just and simple as a corroded wire.
