95 Accord
Nivek1
04-12-2007, 06:29 AM
SO I am doing the brakes ...fronts, caliper is off ..no problem , I took out the 4 12mm bolts that hold the rotor on, but the rotor does not come off..what am I missing, besides gray matter????:banghead:
jeffcoslacker
04-12-2007, 07:20 AM
The rotors are difficult to remove on our years...
1990-95 Accord
See Figures 4 and 5
If equipped with an air bag, disconnect the negative battery cable and properly disable the Supplemental Restraint System (SRS), as detailed in Chassis Electrical (http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0d/0b/57/0900823d800d0b57.jsp).
Loosen the lug nuts, then Raise and safely support the vehicle on jackstands.
Remove the wheels.
Remove the steering knuckle from the vehicle. Please refer to Suspension & Steering (http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0d/1b/39/0900823d800d1b39.jsp)for procedures.
Remove the 4 bolts retaining the hub unit to the steering knuckle and remove the hub unit.
http://www.autozone.com/images/cds/jpg/small/0900823d800d1c46.jpg (javascript:pop()
Fig. 4: Remove the 4 bolts retaining the hub unit to the steering knuckle and remove the hub unit/rotor assembly
Remove the 4 bolts, then separate the hub unit from the brake rotor.
http://www.autozone.com/images/cds/jpg/small/0900823d800d1c47.jpg (javascript:pop()
Fig. 5: Remove the 4 bolts, then separate the hub unit from the brake rotor
To install:
Assemble the disc to the hub unit and tighten the bolts to 40 ft. lbs. (55 Nm).
When installing the hub to the knuckle, use new self-locking bolts and tighten them to 33 ft. lbs. (45 Nm).
Install the steering knuckle.
Lower the vehicle and check for proper brake operation.
If equipped, enable the SRS system and connect the negative battery cable.
mpumas
04-12-2007, 02:03 PM
Do you see a real need to replace the rotors? You don't always need to replace them unless they are scored. And as Jeff stated, replacing them requires special tools.
Nivek1
04-17-2007, 07:28 AM
Do you see a real need to replace the rotors? You don't always need to replace them unless they are scored. And as Jeff stated, replacing them requires special tools. Thanks for the replies..guys...great detail.....another question...reason for all this work ..is that the pass.half shaft broke...the one purchased had what I would call an excite ring for ABS..but this doesnot have it...the shaft looked the same so I installed it ,got to the first corner, right turn and popped out of gear ( for a better word ) lost all drive...pulled the shaft out and the end teeth on the trans side where..lets say missing...now did I 1- not push the shaft all the way on installation....seemed to go in fine or 2 - have the wrong half shaft??? any help would be greatful...Kevin
