2000 express 1 ton vibrationchevyman25 04-11-2007, 12:16 PM i have a 2000, 3500 express and between 65-75 it has a bad vibration i have bought brand new tires from goodyear, new drums and a new axle shaft and didnt help any i took it to a specialist and they said it could be the wheel bearing. would that make it shake that bad its tough to drive it on the highway. its the passenger side that has the vibration. DFBonnett 04-11-2007, 04:33 PM Swap your tires around and see what changes. Most likely cause is an out of balance tire, bad tire, bent rim etc. chevyman25 04-11-2007, 06:50 PM i had all the rims checked and balanced and brand new tires ive had balanced at least four times already they only have about 5000 miles on them would bad wheel bearings make it shake voileintly at high speeds. Fecklar 04-11-2007, 08:05 PM Sometimes, it can shake like that if the parking brake cable has been adjusted too tight. I'm not a professional, but I had it happen to me once on the highway. I thought the wheels were going to fall off. DFBonnett 04-12-2007, 03:58 PM i had all the rims checked and balanced and brand new tires ive had balanced at least four times already they only have about 5000 miles on them would bad wheel bearings make it shake voileintly at high speeds. A wheel bearing that bad would be noticeable if you jack up and spin the wheels in both directions. Usually it will make noise also. Have you considered a bad U joint? chevyman25 04-12-2007, 06:18 PM ive hadem checked too this van must be a lemon its been nothing but problems since day one. i wouold love to take it down south and shoot it full of holes (lol) but its my business van i cant do that. DFBonnett 04-13-2007, 02:41 PM You must have my van's older brother. My 2004 has had a slew of problems too. MT-2500 04-15-2007, 10:58 AM A vibration or shake in the 65-75 MPH range almost always points to tire and wheel out of balance /bad slipped tire belt or bent wheel. Have another repair shop check out the tires for balance and being bad. Or swap a known good set of tires and wheels on it. MT chevyman25 04-15-2007, 02:10 PM thnx for the advice everyone im going to take it to chevy in the morning and let them deal with it ive spent to much time off work and money trying to fix it so im just going to take it to the dealer. chevyman25 04-17-2007, 10:58 AM ok went to chevy they basically charged me 90.00 for nothing they said the rear end needs to be rebuilt which would cost 2500.00 and the exhaust was comin apart so that was 1800.00 and they didnt figure out what was shaking still. i had another shop look at it and they said chevy never looked at the rear end the cover was never touched. i put new shocks and rear shoes on it and it still shakes i guess it has to be the wheel bearings. MT-2500 04-17-2007, 01:02 PM Rear ends do not shake. Jack it up and put stands under rear axle and run it up to 65 MPH and see if it has and shake then remove tires and wheels and run it up to 65 MPH. If it still shakes check for drive shaft shake. If a two piece drive shaft make sure the U joints are in time. Check around Ask around Word of mouth. Family friends coworkers neighbors business people and delivery people. Mailmen and parcel delivery people get around and notice a lot of stuff. Even a good parts house knows what shops are good and not good. Chamber of commerce and better business bureau and city hall. If you find a good referral to a repair shop go look them over and talk to them. Look for a clean looking busy place with nice people running it. Ask a few questions and ask about their qualifications and training. Not all places have trained tech/mechanics. If they do not find a place that does. Even all dealers do not have all trained techs/mechanics. chevyman25 04-19-2007, 08:42 PM alright i put my van in the shop today, took it to a drivetrain specialist and i guess i spun a bearing in the rear end. he told me it might not fix the shake but it could. 800.00 later and a new rear end still shaking like crazy what does it have to do to be considered as a lemon. this has been a nightmare for me i have almost what i paid for it total in just maintance since ive owned it which is less then 2 years. i dont know what else to do im puzzled. chevyman25 04-20-2007, 06:37 PM good news guys i took it to another place today and found out that the drums were unbalanced new drums thing rides like a champ. thanks for the help. Dont always assume that because there new doesnt mean there good!!! MT-2500 04-20-2007, 08:01 PM Thanks for posting back the fix and how it went. Glad you fund the problem. Sounds I take it that new drums takes care of the lemon law. Was the drums replaced before or the ones that came on it? chevyman25 04-21-2007, 11:03 AM we replaced the originals and the ones before both had problems i guess the third time is a charm. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
