98 Bonneville SE Daytime Running lights
gtjayne
04-10-2007, 09:43 AM
I just bought a 98 SE. The manual says that the DRL's should only turn the headlights on at reduced power. When I shift the car in to gear all the lights come on including tailights, full power headlights, instruments, etc. I have read the threads on how to disable the DRLs but I would rather just make them work correctly. Any ideas? Thanks.
ChemMan
04-14-2007, 11:26 PM
Check the light sensor on top of the dash, it might have an open circuit in it.
Good Luck
auto trainy
04-15-2007, 07:47 PM
Or check to see if something is blocking it.
gtjayne
04-16-2007, 09:50 AM
You are right on. Nothing was blocking it but I found out that I accidently pushed it down through the hole while scraping off an old inspection sticker. I felt it happen but thought it was just a plastic fill plug. After getting in there and remounting it properly it works fine. Thanks for your help!
