How to take off 99 contour door panelJon911 04-05-2007, 11:07 PM Hi, I took out all of the screws, however I'm having problems with the door handle. I think this is the only thing that is holding the door on right now. How do I get the door handle off/window thing. beyondloadedSE 04-06-2007, 12:02 AM Did you take the screw off inside the door handle? Jon911 04-06-2007, 12:55 AM Did you take the screw off inside the door handle? Hi, nice picture, tying to keep focus, losing track of main goal. Oh, the car door panel problem. I took the one screw out of the door handle. this is the handle inwhich you use to close the door. The screw was right in the middle of the door handle. The part I'm having problems with is the oval part of the door handle. This part have the handle that you use to open the door. The oval part also have the window button in it. Where is the screw at in this area? pre98zetec 04-06-2007, 04:07 AM Jason43 04-06-2007, 08:19 AM In the oval piece, did you remove the screw behind the door handle? It has a plastic cap over it. beyondloadedSE 04-06-2007, 10:30 AM In the oval piece, did you remove the screw behind the door handle? It has a plastic cap over it. Exactly...this is the one i was referring too. Jon911 04-06-2007, 08:24 PM Thanks for all the great information. The pictures, the detail description of locating the hidden tab behind the door handle was excellent. I was able to get the door panel off after I got that very stubborn tab off. By the way, what did you guys use to get the tab off. pre98zetec 04-06-2007, 09:49 PM flathead screwdriver Jon911 04-09-2007, 01:41 PM Hey, it there a hidden screw right below the mirror panel. The little round circle hole thing. pre98zetec 04-09-2007, 05:49 PM yup Jon911 04-10-2007, 09:35 AM Do you know where I can order more of those little round tabs caps that hide the screws. Jason43 04-10-2007, 11:41 AM The Ford dealership parts desk. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
