door chime still works even wen the key is offfrankfulton 04-03-2007, 07:26 PM I have a 1995 Ford Taurus. When I remove the ignition key the warning chime goes off when I open the door. Sometimes the interior light wont come on either when this happens. If anyone has any ideas please let me know. fubard 04-03-2007, 11:03 PM MY 95 also does this occasionally. In my case it's the key/lock. When I turn it off I can pull the key before the lock is turned all the way off. Then when I open the door the key chime goes off as if the key was still in the lock. If I reach back in I can turn the lock completely off without the key and the chime stops. I have a 1995 Ford Taurus. When I remove the ignition key the warning chime goes off when I open the door. Sometimes the interior light wont come on either when this happens. If anyone has any ideas please let me know. frankfulton 04-04-2007, 06:16 PM Thanks for the info. I probably just need to replace the ignition. Mine will sometimes go off when I turn the key off but other times the chime will stay on. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
