Ignition switch question ?
dawnnewsome3
04-02-2007, 08:38 PM
Can the ignition switch cause the windows and auto seat return to stop working . some time the window works with switch off. seat stoped moving out of the way when switch is off. Any thoughts?
maxnix
04-04-2007, 09:50 PM
Windows should not work with iginition off.
It might be worn. Only item that should be on ignition key ring is its electronic fob. Excess weight will wear out the ignition switch sooner.
dawnnewsome3
04-05-2007, 06:54 PM
That could be problem then ignition switch feels lose and has play , just purchased the car from local banker that didn't keep it maintained . So trying to debug plus replace parts that are almost past repair , but for $800 and she was driving daily who can really complain .
maxnix
04-06-2007, 09:51 PM
Better budget at least $3K to start restoring her unless you want to put her down early.
dawnnewsome3
04-06-2007, 10:33 PM
I added in at least $1500 in parts ,The labor i can do my self worked for GM shop and was ASE certified up to 1999. So the work and getting my hands on the equiptment is still available to me sense my dad still works there.The tricky part is all the schematics in this type of vehicle.
maxnix
04-11-2007, 11:24 AM
Get a 1994 FSM to guide you, along with TSB at
www.nissan-techinfo.com/infiniti/
for a one day subscription.
Early bible sized FSM included in every G50 turn up on eBay or at auto book dealers who buy them off eBay.
Get your parts from www.infinitipartsusa.com
You probably want to replace the complete lockset.
dawnnewsome3
04-11-2007, 09:45 PM
Did get a nissan service manual but it leaves out just minor things like some tourge specs. but it has all schematics plus how to do onboard diagnostics through certian systems. Just not enough hours in the day.
maxnix
04-14-2007, 12:05 AM
Infiniti manuals have all torque specifications. Those fasteners are pretty much identical across the model of G50.
dawnnewsome3
06-02-2007, 07:20 PM
Finally fix the problem, it was the switch.Took me a while to get around to fixing it , a real pain to replace. Thanks for the help.
dawnnewsome3
06-09-2007, 05:13 PM
Well I was wrong inside the door is a box the controls both the window and the power door lock for that door it is called a front power window control module also called P/W amplifier box there is one on each door behind the panel. Hope that helps some one down the road
