radio not working and no dash board soundsdadair 04-02-2007, 05:50 PM Any ideas on why my radio would not be working (the digital screen is showing stations,etc.), but no sound is coming out, and also my chimes are not working like when I leave my keys in the ignition or my change oil light comes on. I checked the fuse and it seems to be okay. Any suggestions as to what it could be? xeroinfinity 04-03-2007, 12:01 AM Welcome to AF. What year / model is your Grand am ? dadair 04-03-2007, 10:13 AM It's a 2002 SE solar-eclipse 04-03-2007, 10:28 AM 2002. hmm you can check the wiring and see if anything is disconectted xeroinfinity 04-03-2007, 11:02 AM Did you check all three fuse boxes? Thier are some for the Body Control Module(BCM) which this controls the chimes and I think part of the sound system. If thier are no fuses or relays blown then you might have a bad BCM, which can usually can only be tested by the Stealership, or someone with a GM Tech II scanner. dadair 04-03-2007, 02:40 PM I am only aware of 2 fuse boxes (driver side and passenger side doors). Where is the 3rd? I figured I would have to take to the dealer, just trying to avoid it if I could figure out for myself. dadair 04-03-2007, 02:42 PM 2002. hmm you can check the wiring and see if anything is disconectted how do I check the wiring? solar-eclipse 04-05-2007, 01:54 PM you can pry out the radio and check for loose wires behind it or if any are disconeccted vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
