1995 Blazer
Google
Web AF
plp7394
04-01-2007, 10:44 AM
I have replaced fuel pump 1 a year for last 3 years. What could be making it go bad? Help?
MT-2500
04-01-2007, 11:54 AM
Welcome to AF.
More info always helps.
What year and what engine?
Some of the main reasons are.
Running tank low on fuel.
Bad wiring to pump.
Cheap replacement pumps.
Bad or dirty fuel.
Clogged fuel filters.
plp7394
04-01-2007, 10:19 PM
.1995 Chevrolet Blazer 4.3 Vortec W series.
I did use a dealer fuel pump. Changed fuel filters.
blazes9395
04-01-2007, 10:33 PM
wiring, poor ground connections, etc. take a close look at the connector, , clean you ground wire connection, and verify through visual inspection/voltmemter that all other wiring leading to the back to the tank is tight and clean.
DelCoch
04-01-2007, 11:39 PM
Constantly running around with less than a 1/4 tank of gas will cause the fuel pump to overheat and fail prematurely. Running it all the way down to empty before filling up is not good either.
blazes9395
04-01-2007, 11:49 PM
I agree....
Google
Web AF
