Nut Size Help ????
eaglebreath
03-30-2007, 08:16 AM
Does Anyone Know What Size Socket I Need To Remove The Front Wheel " Axle To Hub Retaining Nut " On A 97 Lesabre????
Thank You
Rasp
03-30-2007, 12:21 PM
I'm not sure the size but I do remember that when I did this, I was able to borrow one for free from "Canadian Tire" . I think it may be considered a specialty tool.
wrightz28
03-30-2007, 12:24 PM
Shoul dbe able to get with a pair of channel locks, it shouldn't be on tight at all.
BNaylor
03-30-2007, 04:04 PM
Thank You
36mm
:yikes: Dylan, you must have vice grip hands just to be using channel locks. :p
:lol:
wrightz28
03-30-2007, 04:24 PM
You know what, I really, really need to retire, I was thinking wheel bearing lock nut. :(
Yeah, 100 ft lbs might be a little hard for most with channel locks, but not for me :icon16:
eaglebreath
03-30-2007, 08:34 PM
I Tried A 36 Mm.....and The Socket Was Definately Too Big.
If I Had To Guess I Would Say 33 Or 34 Mm...........i'm Hoping Someone
Out There Knows . Just For Clarification......this Is The Nut That
Is Exposed When You Pop Off The Lug Nut Cap On The Alloy Wheels.
Also I Did Find The Specs On The Torque For This Nut ...107 Ft/lbs
Thanks
BNaylor
03-30-2007, 09:48 PM
According to my documentation the other possibility is 34mm since it is not 36mm. The axle nut is what holds the axle shaft (spindle part) into the hub/bearing assembly. Published torque spec is 107 ft-lbs.
