True Oil Pressure Gauge
Google
Web AF
DINO55
03-29-2007, 11:56 PM
Anyone know if there is a spot on a 98 4.3 engine, Other then the sending unit area, where you can pipe in a permanent true oil pressure gauge? If so where?
534BC
03-30-2007, 01:30 PM
sbc have 1/8 pipe plugs , the v-6 is probably same.
MT-2500
03-30-2007, 01:31 PM
I have never found one.
Best bet is just get some fittings and T it in at oil sending unit area.
Good luck
MT
DINO55
03-30-2007, 04:16 PM
Hey MT, Ya think the "T" will have any adverse effect on the Electric oil pressure gauge if I tap into it, At the oil sending unit? That's most likely the route I will go to install a permanent true gauge to the engine...
Thanks for any and all help...
Dino
MT-2500
03-30-2007, 05:33 PM
The electric sending unit will not even know it is T in.
But I would put a new sending unit on.
And route the line for the manual gauge line where it does not rub or burn threw.
The plastic line works good for it.
Good luck
MT
ericn1300
03-30-2007, 08:02 PM
I agree with MT. A mechanical guage is just a calibrated spring guage that wont restrict flow or interfere with the electrical sender that works on resitance changes
Be aware that a mechanical guage in constant use will wear out eventualy just like the electrical units do, even if you choose to go that route fix the factory guage. Redundant guages will give you a greater safty factor. My father inlaw even went so far as to put an oil temp guage on his pickup for when he pulls his 5th wheel.
DINO55
03-31-2007, 06:12 AM
Thanks for the info guy's, I should have made myself a little more clear on this question, My electric guage is working fine. I just never trusted it, Also I wanted to see if there would be any difference's in the oil pressure readings on the True gauge vs. Electric gauge.
Dino
Google
Web AF
