Oil filter change- how to avoid the mess?
Google
Web AF
Caddydrivinmecrazy
03-29-2007, 02:25 PM
I changed my oil last weekend on my 2000 Z71 Silverado. when I pulled the oil filter a bunch of oil collected on the skid plate and got all over my concrete driveway.
Any tips or techniques to keep it out of there? what do yo guys do?
thanks!
lelandatwill
03-29-2007, 05:44 PM
Do it in the grass... Thats what i have to do
Caddydrivinmecrazy
03-29-2007, 06:11 PM
:nono: I don't think so... anybody else?
vnotaro
03-29-2007, 06:18 PM
Pop a hole in the bottom of the filter with a nail and let it drain out before you take it off. If that doesn't appeal to you, then unscrew it very slowly so that the oil runs down the side of the filter and into your drain pan.
Caddydrivinmecrazy
03-29-2007, 06:26 PM
Bingo. The nail idea sounds perfect. Thanks! Draining down the sides of the filter is what made the mess.
ColoradoSilverado
03-29-2007, 07:36 PM
If you don't want to get your hands dirty then don't change it yourself.
Caddydrivinmecrazy
03-29-2007, 07:39 PM
Do you have a reading comprehension problem? Where did I say anything about getting my hands dirty? I was taking about the oil collecting on the skid plate and getting on the driveway when I pulled it out there. Sheesh, trying reading a post before opening your yap.:rolleyes:
MT-2500
03-29-2007, 07:48 PM
thanks!
A big or a bigger drain pan helps.
Sometimes you can take a piece of cardboard or light tin and funnel it over to the side or just remove skid plate.
Cat litter or oil dry helps clean up the mess.
Be sure to wright gm a letter and thank them for a nice set up for changing oil.:grinyes:
Good luck
MT
BlenderWizard
03-29-2007, 08:37 PM
I change mine all the time, and oil never goes anywhere but a little on the oil pan and into my drain pan, and I do nothing special. I dunno how you're getting it all the way up on your skid plate.
In order to get most of the oil off your driveway, though, use some easy off oven cleaner (spray it on the oil spot(s)), let it sit overnight, and then pressure wash it off.
Caddydrivinmecrazy
03-29-2007, 08:48 PM
I was suprised myself, I wasn't even aware that is had gotten on there until I pulled it out on my driveway. Again, this was from removing the filter, not draining the oil. The incline let it drip out and a half hour later I noticed the spot. I will give the oven cleaner a try. Thanks!
FiTxAg04
03-29-2007, 09:55 PM
I quite like Chevy's oil filter layout on my truck. I use an 8 qt. oil pan with a hole in the middle and a spout on the side. I'll drain the pan first and then drop the filter straight into the pan and let that drain out. Never really had any problems with oil spillage and I change it in the street just in case so I don't screw up my driveway. I always buy my oil in the 5 qt. bottle so when I'm done, I transfer the used oil back to that bottle and then take it down to the local O'Reilly's to dispose of.
Tdragone
03-29-2007, 10:26 PM
No Offense; but seriously; you have NO business being under your truck when it's on an incline. Especially if the reason you're under there isn't an emergency.
Even if it takes you driving a few minutes to get to a public parking lot or Park; PLEASE do your maintenance somewhere safe if your driveway and street aren't level.
-Tom D
Caddydrivinmecrazy
03-29-2007, 11:07 PM
-Tom D
Wow, either I am not typing clearly enough or something else is going on here. I NEVER said I changed the oil on an incline. I changed it in the garage then moved the truck out to the driveway (which is inclined). That is when the oil got on my driveway. :banghead:
Caddydrivinmecrazy
03-29-2007, 11:11 PM
Maybe they changed things from the 2000 to the 2004, the oil ran out of the filter and right onto the skid plate. This was after I let the oil drain from the drain plug until nothing more ws coming out.
FiTxAg04
03-29-2007, 11:38 PM
That's what I'm wondering. There's nothing under my filter that would hinder the free flow of oil to the pan. I remember in high school one of my buddies had an '89 Silverado 4x4 and the oil filter on that truck was installed on its side instead of up and down and, to the best of my knowledge, the skid plate and other four wheel drive mechanicals were under it. In order to overcome this, he cut a 1-gallon milk jug in half and held this under the filter, with the spout directed into his drain pan while he removed the filter. Worked pretty well for him.
wrparks
03-30-2007, 09:56 AM
I'm pretty sure they did, because there is nothing under my oil filter and it's pretty easy to do. Now that horizontal oil plug on the other hand, that in my opinion is stupid. 5 qts of oil pressure shootiing ~3 feet to the side when the plug comes off unless you leave the plug in a little and that just takes too long. I had to get a big aluminum tray (wal mart has them buy the way, worth 10 bucks) to cover the ground because I could never figure out where the oil was going to land when the plug first comes out.
Yes MT, I do thank GM for many things, but the oil changing setup is not one of them.
On a further note, have any of you ever looked at the quick oil drain options that screws into the pan and has a valve? Somebody told me about them and they look like a horrible idea. Hit a rock and it breaks off and your stranded.
Blutarski
04-09-2007, 07:09 PM
my 04 2500HD w/ 6.0 has the worst oil drain setup ever! But eht filter isn't too bad. The filter is a pain to get to because it's right next to the pan and you reallt can't get to it. I just go for the "quick like a band-aid" technique, spin it off and flop it into the drain pan. The drain plug, however, is about an inch and a half from the exhaust. That splashes everywhere, including into the skidplate. I was spoiled with my blazer, filter on it's side and an accessable drain. Oh well, I'll put up with it.
I feel your pain... your oily pain.
Google
Web AF
