95 S10, ingnition switch problem?kr10298 03-29-2007, 11:13 AM I have a 95 automatic, When I turn the key to start it, sometimes the dash lights do not appear and the truck doesn't start. I have to turn it back and try again. I will have to do this until finally the dash lights up and then it starts. I suspect the ingnition switch. Has anyone else encountered this? thanks, DENYPA2000 06-05-2007, 11:42 AM I Would Check The Ground Wire Comming Of Your Battery And The Positive To Ensure The Are Not Broke Open Or Have A Loose Connection. If All That Checks Out You Need An Ignition Switch vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
