94 SSE Stallingcobalt53 03-28-2007, 07:18 PM My 1994 SSE has recently started stalling at will, the car runs great and there is no rough running before it quits it just shuts off, throw it in neutral and it starts right back up. Someone suggested that I replace the three coil packs, I did along with the spark plugs and I still suffer the same symtoms, does anyone have any suggestions? Thanks maxwedge 03-28-2007, 07:25 PM Clean the throttle body ,remove the iac and clean this also, if unsuccessful here disconnect the egr for test purposes only. cobalt53 04-04-2007, 03:45 PM After having no success, I gave in and took it to a shop where it was diagnosed with have a clogged catalytic converter, I have never heard of a cat causing that type of symptom? But oh well. maxwedge 04-04-2007, 04:04 PM Never heard of the type of symptoms you describe causing a sudden stall and restart, attributed to a clogged cat. Something may be going on the caused the cat problem, just be aware. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
