aftermarket headlightsTonyr 03-27-2007, 08:34 PM I bought a pass side headlight from ebay a while back. This one does not seem to be made as well as the OEM one. I should have guessed that it was "cheaper" because it was only $66. The light seems to bounce around when hitting a slight bump or rough roads. You can see the beam vibrating when the light shines on another vehicle on the highway. Anyway, I want to get an original, not some generic remake. Where is the best place to get one or does anyone have an original laying around the shop they are not using? jeepgclwj 03-27-2007, 09:31 PM Any GM stealership would be able to get you one. Junk yard possibly or there are a couple of other Grand Prix forums out there that have alot of stuff being sold. Google search GTP forums and you should find what your looking for... 1typhoon 03-30-2007, 09:47 PM I bought a pass side headlight from ebay a while back. This one does not seem to be made as well as the OEM one. I should have guessed that it was "cheaper" because it was only $66. The light seems to bounce around when hitting a slight bump or rough roads. You can see the beam vibrating when the light shines on another vehicle on the highway. Anyway, I want to get an original, not some generic remake. Where is the best place to get one or does anyone have an original laying around the shop they are not using? I also bought a headlight assembly from ebay. I found it to be of at least equal to, if not better quality than OEM. Mine fits snuggly and works great. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
