oil pressure|97BlaZeR| 03-27-2007, 03:53 PM 1997 blazer 4dr 4x4 my oil pressure feathers between 45 - 75 and it used to stay solid at around 75... should i be concerned about this? BlazerBoyLT98 03-27-2007, 03:57 PM Completely normal I would say |97BlaZeR| 03-27-2007, 04:00 PM alright thanks again there is no weird sounds/it accelerates fine/no knocking just wanted to be sure MT-2500 03-27-2007, 06:34 PM It should not be feathering or moving around. If it is a electric oil pressure gauge. Time to put a manual test oil pressure gauge on it and find the real pressure. If good steady pressure on a manual test gauge check the oil pressure sending unit. MT drdd 03-27-2007, 11:19 PM it should not flicker around on its own. It will however, move in relation to engine speed (when you press the gas pedal). 20 - 80 is normal on a 1997. 1997 blazer 4dr 4x4 my oil pressure feathers between 45 - 75 and it used to stay solid at around 75... should i be concerned about this? |97BlaZeR| 03-28-2007, 04:26 PM today it was about 20 degrees cooler and it stayed relatively solid at 75. i still want to check it though vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
