Help! Car Won't Start!!!luarg2 03-27-2007, 12:27 PM I went to the gas station last night because I was low on gas (just fumes) I pumped my gas and went to start the car and it would crank but not kick over and start. I did this a few times to no avail. I know it has to be a problem with my fuel but I was wondering if anyone might have some suggestions. Also the past 2 months it has been bogging down when driving and when at idle a handful of times the cars rpms would drop for a second and then recover. I don't know if these may be tell signs of a fuel issue? richtazz 03-27-2007, 03:02 PM IF you run it often below a 1/4 tank, your fuel pump is probably going/gone out. Fuel cools the pump, and running near empty overheats it. A fuel presure test would confirm. Gems 03-27-2007, 06:51 PM Rough idling could also be just some simple tune up items... Dirty MAF, dirty IAC, dirty throttle body, vacumn leak, plugs, ignition wires, etc etc... luarg2 03-28-2007, 12:15 PM It was my pump. I installed a new pump last night (very DIY). Problem solved. it almost feels like a new car because it accelerates alot better. I also got my fuel guage back as well thanks to the new float. Thanks for replies vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
