Let's try again!sassee 03-25-2007, 07:33 PM Finally got a little time to spend with the troop. The idle is still surging/fluctuating/whatever. I replaced the intake gaskets when I put in new injector seals. I replaced all of the vacuum lines and rerouted according to the diagram. I sprayed all around the engine and vacuum lines, I'm fairley certain it's not a vacuum issue. The tranny is still shiifting weird into O/D. when I go thru the gears manually and then hit the O/D button, it shifts smooth as silk. when I start in Drive and go thru the gears, it can't make up it's mind if it really wants to go into O/D or not. Any help on these items greatly appreciated. Ernie By the way.................... the cranking issue appears to be resolved. the ignition switch was full of crud! I used some electrical contact cleaner and cleaned it up. Then went thru all connections under the hood and the computer connections also. still has a minor electrical issue. When I hit a big bump in the road, the radio wants to go off momentarily. I'll go thru all of the ground points this week and clean then up. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
