transmission replaceenginereplace 03-24-2007, 11:27 PM Hi i have a 95 lumina apv and i'm trying to get the transmission out. I removed all 6 trans screws,mounts,and the pass trans end mount,cv joints,converter bolts,wireing even the impossable bolt thats only accesable from the pass side way in the back,plus the starter and this supid trans only comes off the motor on one side .the side by the radiator only.It seems to be stuck or i have forgotten something somewhere. Anyone got any ideas???? Could it be that i need to remove the trans dipstick tube also? I dont think i did that . anyway...any help would be awsome :) Thanks! James LMP 03-25-2007, 12:13 PM You did not mention if you had the engine/transmission cradle down....(standard procedure)...If you are taking the transmission out withoutdropping the subframe, it would be worth taking some pictures and make them available . IN "95, there were 3.1 and 3.8 available, one with 3T40, the other with 4T60. Which is yours? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
