Mystery Hose on 93 5.8torino21 03-21-2007, 10:33 AM I have a hose that is busted on my 93 5.8 F150. It runs from the behind water pump to an aluminum tube back to rubber to the heater core. Any help? MT-2500 03-21-2007, 01:22 PM Remove it and head for the auto parts place or dealer for a replacement hose. Is it clamped on on both ends or does it have a crimp fitting on one or both ends? If you could post a picture we could see what hose or kind of a hose it is. torino21 03-21-2007, 02:46 PM It is clamped on the water pump end, but crimped on the other end. I will try to post a picture asap. MT-2500 03-21-2007, 04:39 PM A picture may help. But It would be better to see if parts place or dealer can get the hole hose pipe and hose together. In case of a emergency repair you may be able cut the crimp off and clamp on a hose. But the factory set up usually is the best bet. Good luck MT vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
