someone jacked my antennaspeeddevil 03-20-2007, 11:47 PM my antenna is missing and no base as weel. what is the proper way to remove one from the car cuz now i got to go and jack one from da junk yard 1968 Pontiac 03-25-2007, 10:21 AM If it's like the 91-96 power or manual antennae: -disconnect the antenna lead under the hood at the firewall -disconnect the power lead in that same area if you have power antenna -remove the inner fender on your good car; remove the inner fender rear bolts and bend the inner fender to gain access the back side of the fender -use an antenna nut wrench to remove the nut on the top of the fender until it is hanging on by a few threads (i.e. finger tight) -open the passenger door and remove the bolt about 6" down from the top hinge -remove the antenna nut and the antenna will fall out the bottom vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
