Rough Running
DirtyBird114
03-09-2007, 06:05 PM
I have a 1992 Toyota Camry with about 130,000 miles. It cranks fine and runs good until it gets warm. It then starts idelling bad and goes dead. I have had it in the shop several times but they cannot find the problem. This last time they replaced a fuel/air sensor that the o-ring was warn out on. But it is still doing the same thing.
Any help is welcomed.
DB114
RIP
03-10-2007, 02:16 AM
Clean or replace the idle air control valve, or was that the sensor they changed? If so you may have a sticking EGR valve or vacuum leak at the intake manifold. Wouldn't hurt to thoroughly clean the throttle body with a spray cleaner.
DFBonnett
03-11-2007, 01:56 PM
Consider the possibility of it being an ignition problem such as the coil or igniter acting up when hot.
You can download a manual here... http://oregonstate.edu/~tongt/camry
and go through the diagnostics.
