01 WJ Elecrtical problem(s) adviceswanem 03-07-2007, 04:22 AM Three years, 2 questions...whew! I'm on a roll! This is a newly acquired 01 WJ, and some problems have started surfacing. I'm 90% sure I know what the problem is, but I wanted some advice before tackling something I don't have to do. I checked the FSM, and that's where I got my conclusion from. Some of the issue's I am having: No heated seats, lights come on, but no heat. Heated mirror on Driver's side looks "burned" around the edges. Brown fading to yellow in the center. Memory and adjustments from inside are fine. No cruise control. Light comes on on the dash, but there is no control. When I put on my intake this week I'm gonna check to make sure the vacuum hose is attached. Center console lights just stopped working last night. From the radio (which comes on, just no lights) all the way down to the PRNDL light including the XFer case light. No AZC for the A/C. Now this could be the door problem, or my anticipated problem. Last week the rear wiper would not return to the off position on the rear hatch back. I smoothed out the plastic thingys with some 600 grit sandpaper, and it works now, but this may or may not be related.I have checked all the fuses and they are all good. I didn't check the relays, but I could not find anything that would control any of these issues. If anyone has the same idea (or any idea for that matter) I'd like to hear it before I take it to the stealership for diagnostics. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
