Our Community is 705,000 Strong. Join Us.
Navigation in Standby mode
cclchl
03-06-2007, 09:01 AM
has anybody had any problem with the navigation system in their truck. Mine is in stand-by mode and will not let me turn on. Please help? thank you in advance.
Towncar
03-06-2007, 04:05 PM
How's you battery / alternator? The nav system requires 10v minimum to operate. I can start quoting from the manual, but the first 4 or 5 diagnostic steps require testing for greater than 10v at specific connector plugs.
SAMPLE:
Navigation System
PINPOINT TEST B: NAVIGATION SYSTEM WILL NOT SWITCH ON
B1: CHECK CIRCUIT 1002 (BK/PK) FOR VOLTAGE
B2: CHECK CIRCUIT 729 (RD/WH) FOR VOLTAGE
B3: CHECK CIRCUIT 1002 (BK/PK) FOR AN OPEN
B4: CHECK CIRCUIT 729 (RD/WH) FOR AN OPEN
B5: CHECK CIRCUIT 1537 (RD/BK) FOR VOLTAGE AT THE NAVIGATION SYSTEM DISPLAY MODULE (NSDM)
B6: CHECK CIRCUIT 57 (BK) FOR AN OPEN
B7: CHECK THE NAVIGATION SYSTEM CONSOLE HARNESS
PS:
Technical Assistance is available by phone:
If there are problems during the diagnosis or it is not clear how to proceed with the repair, call Technical Assistance. BEFORE calling Technical Assistance, the Navigation Function Test must be carried out. The following information is needed to identify the system and software version. This information is available by selecting "Main Menu", "Settings", "System Information", "Configuration". "System Identification" information will appear. Please have this information and a detailed description of the problem.
Technical Assistance 1-888-253-5890 (Hours of operation: M-F, 9am to 6pm EST).
Can you alternate to the "Settings" menu ? This is where the system information is stored.
cclchl
03-07-2007, 12:18 PM
My battery is new. I can't select any other mode. None of the buttons are functional. I can't even recall when it stopped. I will try and do the test to see what happens. Thanks again.
