Keyless remote programming
Mineus
02-27-2007, 01:37 PM
Hello, I recently bought an 03 GTS, but the seller didn't give me any remote keys. I wanted to have keyless system and then found out from the dealer that this car already has a factory keyless system.
So I am thinking of getting the transmitter key off Ebay or various sites. However I am a little puzzled as to the many kinds of keys available (and claimed to fit an 03 eclipse). There are the two-button (lock and unlock) transmitter, another that has trunk release included, and some with panic button. My question is, which is the actual one that is for an 03 GTS? I was able to learn from the dealer that my car has the keyless and alarm system. Also, are there system that don't allow the trunk release? Please advise me. Thanks!
Andrew
Andrew
808drifter
02-27-2007, 01:59 PM
As far as I know, our cars dont have a trunk release. As for the remote, the factory one i recived had 4 buttons witch are programable. As for programing it, it's a long process.
1st step flip the valet switch to on,off 3 times Car should chirp once. Hold the button you want to lock the car untill alarm chirps. \
2nd step Flip valet switch on,off once, It will chirp twice. Hold whatever button you want to unlock the car untill alarm chips agian.
Your done. On and off may be switched IDK. You can set up to 6 differnt things but all you need is the first 2. Holding the Arm/lock car button down will act like a panic button. Valet switch is a little silver switch under dash below the drivers side fuse box.
These are all refering to how my car is, I have a factory Alarm.
Mineus
02-27-2007, 03:34 PM
So I should buy one that only has the lock/unlock feature? I would love to have a trunk release though.
Btw, the programming instruction you provided is quite different from any that I have found around here or google. Most of what I found required tampering around with the pin 1 and 4 of the DLC underneath the dashboard. Is yours an 03 GTS hatchback too? Were you re-programming old key or programming new key? Mine has a manual trans(if that makes a difference).
Andrew
Andrew
808drifter
02-28-2007, 08:29 AM
Had to re-program factory key cause battery in it died.
Thats how you reset the factory alarm. If anything just find out what company made your alarm and look for the manual onine thats what I did.
Onblsht
03-03-2007, 08:20 PM
The 2002+ models use FCC: OUCG8D-525M-A. Whether the remote has the TRUNK button or not on the outside, all the circuit boards DO have that circuit pad on them, you just can't press it on the 2 button remotes.
sk72
03-29-2007, 03:22 PM
I have a 2002 Mitsubishi Eclipse GS. I bought a keyless remote from ebay and am trying to figure out keyless programming. I can't seem to locate the valet switch.
Please help.
Thanks in advance.
SK
Please help.
Thanks in advance.
SK
808drifter
03-29-2007, 03:43 PM
This is where mine is.
http://i9.photobucket.com/albums/a67/808drifter/VALETSwitch.jpg
sk72
03-29-2007, 04:08 PM
Thanks Drifter,
I did open up the fuse box near the driver side...but could not find the valet switch...Is it inside the fuse box or next to the fuse box?
Thanks again.
SK
Thanks again.
SK
808drifter
03-30-2007, 09:27 AM
On bottom of dash.
Next to a bolt.
Where outside bottom of dash bolts to car.
Next to a bolt.
FredDro80
04-02-2007, 04:25 PM
:banghead: hi to all, i bought a 2000 eclipse that came with one remote, which does not work. i've looked online for weeks on how reprogram it. everything i've read hasn't even begun to work. then i hear that the programing is different for the 02 and up. if anyone has any suggestions on how to do this i would be more than greatful.
Onblsht
04-02-2007, 07:24 PM
Sounds like you may have the wrong remote...since the instructions look the same from 2000 and 2002. What numbers are on the back of your current remote?
FredDro80
04-05-2007, 09:49 PM
thanx for ur reply onblsht. the numbers on the back are : FCC ID: NYG12ABA.the letters and numbers are very tiny and worn so i may have read then wrong. it has a mitsubishi symbol on it?
Onblsht
04-06-2007, 12:47 AM
It sounds like they're just too worn to read, but the numbers are HYQ12ABA
redwilly
08-19-2007, 01:10 AM
hey i have a 2001 mitsubishi galant with alarm, my fcc is hyq12aba as well and i cant figure out how to program it there is nothing about it online, and many people have told me that 2000+ models cannot be programmed except by the dealer. anybody know if/how it can be done?
808drifter
08-20-2007, 03:09 PM
Made a post. Read it.
