Speedometer Accuracy
Google
Web AF
optraowner
02-26-2007, 05:33 PM
Did you know that your 2004 - 2007 Chevrolet Aveo might not have an accurate speedometer reading?
I have a 2007 Optra LT and found this out when I hooked up my GPS system and there was a difference of 3 to 9 KMH. I wouldn't have even known there was a problem and you might not either. Spoke to GM head office and my dealer and they feel it is no big deal but I feel it is a safety issue and the speedometer should be accurate.
It seems this issue has been around for a while and no complaints, as you might not even know about it. My dealer though I was nuts when I told them this a week after getting my new 2007 Optra LT.
Check you maybe surprised.
Here is something else I found on a search on the web
Auto Repair Information » 2004 Chevrolet Aveo LS Wagon
2004 CHEVROLET EPICA, OPTRA ALSO INCLUDED. ... Description: SPEEDOMETER ACCURACY 7 TO 9% HIGHER THAN ACTUAL.
GM bulletin reads
Subject: Speedometer Accuracy Higher Than Actual - Keywords IPC miles ,mileage odo odometer offset speedo #PIC3779B
(01/15/2007)
Models:
2004 - 2006 Chevrolet Epica (Canada Only)
2004 - 2007 Chevrolet Optra (Canada Only)
2005 - 2006 Pontiac Wave
This PI was superseded to add the 2005-2006 Pontiac Wave. Please discard PIC3779A.
The following diagnosis might be helpful if the exhibits the symptom(s) described in this PI.
Conditions/Concern:
The speedometer may indicate vehicle speeds higher then actual. For example, the speedometer may indicate 60 mph at an actual 55 mph.
Note: The odometer accuracy is NOT affected as this is a speedometer ONLY issue.
Note: This is characteristic of the current calibration.
Recommendation/Instructions:
This condition is NORMAL at this time; do NOT replace the IPC for this conditions it will NOT repair this speedometer offset condition.
optraowner
03-06-2007, 06:38 PM
I bought my Brand New less then 2 months old in to the dealer for the 5th time.
Here are the test of side by side driving with my vehicle
Service Car 20 40 60 80 100
Customer Car 24 48 68 88 106 All speed are in kph
See not accurate at all and no consistancy in the ammount it is out by.
If you own any of these models
I would bring it back to your GM delaer and get them to test them as I bet your vehicle speedometer will be off as well like the other people I have spoke to.
If the dealer says you are crazy tell them to read GM Bulletins 3779, 3779A & 3779B as they have know about this since 2004 and yet there still is no fix for this.
463
05-06-2007, 11:44 PM
take the gps and test it out.thats the best way to accurate calibrate the speedo.
rhandwor
09-05-2008, 08:11 PM
For accurate calibration use a company such as this.
http://www.speedometerservices.com/index.html
Google
Web AF
