Engine Swap From 96 Malibu 3100 Series To 91 Luminaguambombboy1 02-23-2007, 05:33 AM Does The Transaxle Match Up Or Not? richtazz 02-23-2007, 07:43 AM First off, GM didn't make a Malibu in 96. Secondly, although the trans mount bolt pattern is the same, the engines are not interchangeable. There are too many differences to go into here, but the only real similiarities between the 3.1 in the 91 Lumina and one from a 97-up Malibu are the 60 degree V-6 configuration and the displacement. wafrederick 02-23-2007, 06:06 PM You read the built date wrong and if the build date is november and up of 1996,it is a 1997.It will not fit,you will have to find a 1990-1993/1994 3.1. Automotive Network, Inc., Copyright ©2012
