2001 mirage gauges won't work?craigsgirly47 02-22-2007, 05:27 PM I have a 2001 Mitsubishi Mirage and out of the blue one day all the gauges just quit, all at the same time. A little later they started up again. Next day, they go off. They seem to go off only after I've driving for a while then when I start the car up again they are off. most recently I've figured that when the car is warm (I've already driven it once that day or the sun has been shining in it, heating up the car) that's when they won't work. When it's cold outside and the sun isn't out, then they work. what could be probelm and how do I fix it since winter is almost over? Litto 06-05-2007, 04:04 PM I have a 2001 Mitsubishi Mirage and out of the blue one day all the gauges just quit, all at the same time. A little later they started up again. Next day, they go off. They seem to go off only after I've driving for a while then when I start the car up again they are off. most recently I've figured that when the car is warm (I've already driven it once that day or the sun has been shining in it, heating up the car) that's when they won't work. When it's cold outside and the sun isn't out, then they work. what could be probelm and how do I fix it since winter is almost over? how did you fix it? How much did it cost you? What was the problem? what cause it? Litto:frown: Mitsitech001 06-07-2007, 11:49 AM Hi there, looks that your problem must be in the wiring connections that have got poor contacts. May be you can remove the instrument cluster, remove the connectors and check for oxidation, clean and spray some contact cleaner in the connectors. This should do the job if not the only thing left is to pay a visit to an electrician. Cheers. Automotive Network, Inc., Copyright ©2013
