1993 Blazer 4.3 vin w
Google
Web AF
Glennyboy
02-17-2007, 03:35 PM
Hi all
I just bought a clean Blazer .....,, coolant loss motor knock.... so i am looking for a used motor, the only thing is that year used motor has high miles at the junkyards. Could i use a 99 model 4.3 engine, and will the intake manifolds interchange along with other parts from the motor thats in the vehicle now.
1993 Blazer 4.3 vortex engine.
Glennyboy
02-23-2007, 12:20 AM
Hi all
Pulled the motor, knock was piston meltdown on two cylinders, .005 warpage in the block deck, plus warpage in the heads. Cylinders honed up ok, but i will have to take it to the machine shop for a complete check over. Undecided what to do,,,,,rather rebuild this one than put in a used one
Chris Stewart
02-23-2007, 08:17 AM
If you build this one, you'll know what you have. Don't forget the heads, a nice 3 angle valve job and they'll flow pretty good. Ask about a milage cam...might as well get some fuel milage & low end torque out of this project.
A transmission fluid & filter change...dumping the old fluid out of the torque converter since it's easy at this point.
You could end up with a very solid piece at 1/10 the price of new.
I'm looking forward to mine when it's time.
Google
Web AF
