abs controllerPhillip Cross 02-12-2007, 01:51 PM My abs pump started running all the time. I unplugged the controller to stop it. searching for part on the internet i found a company that rebuilds the module for $150. the site says that the truck can run wihtout the controller while waiting for the rebuild. removal of the control unit is via 4 torx screws. Must send to rebuilder and wait for return. Anyone with experience with theis rebuild option? Dealer wants about $700for the part and 200-300 labor. Ouch -- another blaxzer weakness? (Along with my front hubs, oil cooler hoses. radiator failure and intake manifold gaskets all before 60K MT-2500 02-12-2007, 05:23 PM My abs pump started running all the time. I unplugged the controller to stop it. searching for part on the internet i found a company that rebuilds the module for $150. the site says that the truck can run wihtout the controller while waiting for the rebuild. removal of the control unit is via 4 torx screws. Must send to rebuilder and wait for return. Anyone with experience with theis rebuild option? Dealer wants about $700for the part and 200-300 labor. Ouch -- another blaxzer weakness? (Along with my front hubs, oil cooler hoses. radiator failure and intake manifold gaskets all before 60K What year is it? You may be good shape if it is the module. But if not it will be back to the old drawing board. Did you check it out first? Did it have any abs codes? MT Phillip Cross 02-12-2007, 06:08 PM It Is A 2000. The Rebuild Company Tests Before Billing. The Symptom Is That The Puimp Stays On Even When The Key Is Turned Off. Doesnt That Mean That It Is Most Likely The Computer Module? MT-2500 02-12-2007, 07:19 PM It Is A 2000. The Rebuild Company Tests Before Billing. The Symptom Is That The Puimp Stays On Even When The Key Is Turned Off. Doesnt That Mean That It Is Most Likely The Computer Module? May be or may not be. The only way to test is to start with the codes. ABS light on? Have you got Got codes? Phillip Cross 02-13-2007, 09:59 AM YES ABS LIGHT ON. I GUESS I SHOULD TAKE TO THE DEALER TO GET CODES? HERE IS THE LINK FOR THE REBUILD COMNPANY IN CASE YOU ARE INTERESTED. http://cgi.ebay.com/ebaymotors/ABS-Module-Rebuild-GM-GMC-Chevy-Sierra-Silverado-EBCM_W0QQitemZ280080590198QQihZ018QQcategoryZ33560 QQrdZ1QQcmdZViewItem frehol 02-14-2007, 07:19 AM Hey, no need to "SCREAM"! Even though it can be hard to keep calm when your truck is sick ;) Phillip Cross 02-14-2007, 10:23 AM sorry. i am an old man whose typing skills are poor. did not know caps meant anything. i dd not even notice that the caps lock was on. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
