01 cavalier radio LOC
spicymchaggis13
02-07-2007, 11:42 PM
Hey everyone,
I know you guys have probably seen this a hundred times and im sorry but I have a little different problem besides my radio being locked. Whenever I go to use the steps to get the code I can never get the radio to turn off. It stays on all the time unless I open the door. Now this is a radio i bought stock radio I had was aftermarket but ended up dying on me. Any sugestions I want to unlock it but I cant even get it to turn off ive tried everything. thanks in advance and again sorry
also it doesnt say rds anywhere on it so its not that
muff34
02-08-2007, 11:45 AM
[quote=spicymchaggis13]. [Any sugestions I want to unlock it but I cant even get it to turn off ive tried everything. ] This Is confusing ,it`s not locked if you can`t turn it off???? The stereo in these cars will stay on for a couple of minutes after car has been shut off ,until you open the door .Can`t remember hoew long it stays on .
spicymchaggis13
02-08-2007, 11:51 AM
the cd player is locked its says LOC and the only way it can turn off is if i open the door like usual but i cannot turn it off using the power button and when i hold the preset buttons down it does nothing.
sorry when i said unlock i meant unlock the radio
muff34
02-08-2007, 12:00 PM
All the wiring is original, nothing cut or spliced ? Soon as you turn key on it displays "LOC" and not "LOCKED" correct. if you have not turned key on there is nothing on display ....Correct?
spicymchaggis13
02-08-2007, 12:06 PM
yes that is correct no spliced wires all original and its says LOC and only when i turn the key
muff34
02-08-2007, 12:08 PM
so you have turned the key to on position , and held down the preset 2 and 3 for six seconds , and nothing changes ?
spicymchaggis13
02-08-2007, 12:11 PM
correct it just says loc now my cavalier came stock with a tape player its a lower model and after my jvc died i figured i would just get this assuming it was compatible
and here is a link http://i6.tinypic.com/4d3hmqp.jpg
if it helps any thats my radio
muff34
02-08-2007, 12:17 PM
correct it just says loc now my cavalier came stock with a tape player its a lower model and after my jvc died i figured i would just get this assuming it was compatible look this procedure over and see if you missed anything.(lots of crap you don`t need ,but you`ll figure it out )http://www.automotiveforums.com/vbulletin/showthread.php?t=310354. hopefully it will help ,if not maybe it has to go back to dealer.......unfortunately. MY `00 sunfire came stock with el cheapo tape player /stereo also . The monsoon stereo I put in it was out of a `01 Grand Am . It Displayed "LOCKED" .I had to take it to dealer to have it scanned /retrained. LET US know if this works
Good Luck MUFF
spicymchaggis13
02-08-2007, 12:22 PM
Good Luck MUFF
ok thanks alot for your time I appreciate will def. look it over a couple times thanks again
spicymchaggis13
02-08-2007, 02:35 PM
well i tried it a couple times nothing but the guy said he will send me an unlocked one so hopefully that will work but idk
